Iso block insertion point
I created a new component; placed in catalog; created an symbol to be inserted.  The component is an extended body gate valve.  Basically a gate valve with a pipe nipple attached.  Problem is that I am having trouble with the insertion point and having the valve insert in the correct orientation.  Insertion point is always on the PL nipple end.  It is a SW x Thd valve.  Any ideas that can help with this?
You can see in the attachment, the valve should be inserted like the middle valve always
Corey.M.Gentry
I am having the same problem with extended body gate valves.  Did you ever find a fix for this issue?
Thank you
