Is there an easy way to add 550mm size to spec
mailZU2NV
mailZU2NV
I am working on a ship that has 550mm pipes, is there an easy way to just change all the parts of a spec to 550, I tried to do all the components I need one by one, but now I get errors when I try to connect them.
MateusMaciel
According to the images, follow the following steps in the spec editor:
1- Select edit catalog in mm;
2- Enter the length of the pipe in the Fixed Length property;
3- Check the box next to the Use Fixed Length property;
mateustilapa@gmail.com
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
Hi Mariah,
I understand that the ND is 550mm and not the length, right? But connection doesn't work? Note that the connections are set in Project Setup, node "Plant 3D DWG Settings - Piping Connection Settings". All joints need by default the ND as a required match to add for example flanges, bolt set, gaskets, etc. This means that for all other components you will need the size 550 for them as well. So, add the size 550 mm to all components of your spec.
You might note that the size 550 mm isn't listed in the selection list for sizes for new components. You have to adopt before the NominalDiameterMap.csv from program folder (afterwards you have to restart the Spec Editor) to get this size added. Read this article for further information.
Please, let us know if I could help you.
Best regards
Bernd
Bernd G.
Senior Product Support Specialist
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
