Hi.
After almost a month trying to create my company's Plant3D template, we found out that most companies don't stick strictly to one single standard when they draw P&ID objects in normal CAD. They mix symbols of PIP, ISO and ISA usually. So, half of the native tool palettes for equipment and instruments usually is useless and needs to be customized. But, drawing and creating new P&ID objects from scratch is too much time consuming, and many of the P&ID objects I want, Plant3D already have them in a different standard than the one I'm using. So, I was wondering if it's not possible to change the standard symbol Plant3D is using in the tool palettes, overwriting the native choice.
For example, if I'm drawing in an ISO standard drawing but I want the butterfly valve to be represented just like it appear in the tool palettes for the PIP standard, is there a easy way to make that change?
If I just change the tool palettes from ISO to PIP and try to use the objects, I'll get an error saying that I can't use the PIP object in a ISO drawing.
Hope I could make my question clear here. Please let me know if I wasn't clear enough. Thanks
