@rajendra.prajapat thanks for the reply. My problem lies with the If Else's that predefine some steel profiles and shape types inside the code. I can create it in this manner for either metric or imperial unit systems, the problem is when I try to use the mixed units systems, where plant3d automatically convertes from inches to milimeters. Since pipping frequently uses the imperial system for its diameters and in Brazil we use the metric system for anything else, it's quite common for projects to use mixed units. For obvious reasons plant only converts the parametric values defined in the function call and declared as length parameters in the parameter list. If there was any way to figure out the active unit type (inches or milimeters) at runtime, I could simpy make a switch and decide wchich unit to provide the script. If not, declaring everything in metric system in the spec editor will work, since the code works just fine. If there is such a function or flag that provides me the unit system, It would be very nice though.
from varmain.primitiv import *
from varmain.custom import *
from math import *
# region METADATA #
@activate(Group="Support", TooltipShort="SP-14", TooltipLong="SP-14", LengthUnit="mm", Ports="1")
@group("MainDimensions")
@param(D=LENGTH, TooltipShort="Diametro do tubo, OD", TooltipLong="Diametro do tubo, OD")
@param(L=LENGTH, TooltipShort="Comprimento do suporte", TooltipLong="Comprimento do suporte horizontal")
@param(H=LENGTH, TooltipShort="Altura do suporte", TooltipLong="Altura do suporte")
@param(TP=ENUM, TooltipShort="Tipo", TooltipLong="Tipo:\n 1 -> Tipo I;\n 2 -> Tipo II;\n 3 -> Tipo III;\n 4 -> Tipo IV.")
@enum(1, "Tipo I")
@enum(2, "Tipo II")
@enum(3, "Tipo III")
@enum(4, "Tipo IV")
@param(CL=ENUM, TooltipShort="Classe", TooltipLong="Classe:\n 1 -> Classe A;\n 2 -> Classe B;\n 3 -> Classe C;\n 4 -> Classe D.")
@enum(1, "Classe A")
@enum(2, "Classe B")
@enum(3, "Classe C")
@enum(4, "Classe D")
# endrgion
def SP14(s,D=114.3,L=400.0,H=400.0,TP=1,CL=1,**kw):
# region COMMON variables and configuration #
#Rebar Diameter
DR = 19.0
#Rebar Endpoint Height
HR = 75.0
#Rebar bend radius
RR = 20.0
#Rebar offset size reduction
ROF = 50.0
#Steel Profile Height
A1 = 102.0
#Steel Profile Width
B1 = 102.0
#Steel Profile Thickness
TH1 = 9.5
TP = int(TP)
CL = int(CL)
if not (1 <= TP <= 4):
TP = 1
if not (1 <= CL <= 4):
CL = 1
# Class configuration for the SP-01 support catalogue
if (CL == 1):
A1 = 51.0
B1 = 51.0
TH1 = 6.4
elif (CL == 2):
A1 = 64.0
B1 = 64.0
TH1 = 6.4
elif (CL == 3):
A1 = 76.0
B1 = 76.0
TH1 = 9.5
elif (CL == 4):
A1 = 102.0
B1 = 102.0
TH1 = 9.5
#Size verifications
endpoint_length = RR + DR/2.0
if L < D + endpoint_length + A1 :
L = D + endpoint_length + A1
if H < D + DR + A1:
H = D + DR + A1
#Beam
beam_length = L
if (TP == 1) or (TP == 2):
beam_x_cut_shift = TH1
beam_z_cut_shift = -TH1
vp_x_cut_shift = TH1
vp_z_cut_shift = TH1
else:
beam_x_cut_shift = -TH1
beam_z_cut_shift = TH1
vp_x_cut_shift = -TH1
vp_z_cut_shift = -TH1
b_y_shift = 0.0
b_z_shift = -D/2.0 - A1/2.0 - DR
#Vertical profile
if (TP == 1):
vp_height = H - DR
elif (TP == 2):
vp_height = H - DR + ROF
elif (TP == 3):
vp_height = H + DR + A1
else:
vp_height = H + DR + A1 + ROF
#45 degrees chanfer
ch_radians = radians(45)
ch_length_ad = 2*A1*sin(ch_radians)
ch_shift_beam = (0, beam_length/2.0 - A1, -A1/2.0)
ch_shift_vp = (0, vp_height/2.0 - A1, A1/2.0)
#Rebar
rebar_length = 0.0
r_x_shift = (DR - A1)/2.0
rebar_top_height = HR - RR
rebar_length = beam_length - endpoint_length
r_y_shift = (rebar_length + endpoint_length)/2.0
r_y_shift_bend = -r_y_shift + DR/2.0
else:
rebar_length = beam_length - A1 - endpoint_length
r_y_shift = (rebar_length + endpoint_length - A1)/2.0
r_y_shift_bend = -r_y_shift - A1 + DR/2.0
r_z_shift = -D/2.0 - DR/2.0
port_y_shift = 0
if (TP == 3) or (TP == 4):
port_y_shift = (endpoint_length - A1)/2.0
port = (0, port_y_shift, 0)
# region Horzintal Profile, main support profile for all types #
beam=BOX(s,L=beam_length,H=B1,W=A1)
vp=BOX(s,L=vp_height,H=B1,W=A1)
chanfer=BOX(s,L=ch_length_ad,H=B1,W=ch_length_ad).translate((0, ch_length_ad/2.0, -ch_length_ad/2.0)).rotateX(45)
chanfer.translate(ch_shift_beam)
beam.subtractFrom(chanfer)
chanfer.erase()
chanfer.translate(ch_shift_vp)
vp.subtractFrom(chanfer)
chanfer.erase()
beam_cut=BOX(s,L=beam_length,H=B1,W=A1).translate((beam_x_cut_shift, 0, beam_z_cut_shift))
beam.subtractFrom(beam_cut)
beam_cut.erase()
beam_cut=BOX(s,L=vp_height,H=B1,W=A1).translate((vp_x_cut_shift, 0, vp_z_cut_shift))
vp.subtractFrom(beam_cut)
beam_cut.erase()
vp.translate((0, vp_height/2.0, -A1/2.0)).rotateX(90).translate((0, L/2.0 - A1, -vp_height + A1/2.0))
beam.uniteWith(vp)
vp.erase()
beam.translate((0, b_y_shift, b_z_shift))
else:
beam.rotateY(180).translate((0, b_y_shift, b_z_shift))
#Top rebar
rebar = CYLINDER(s,R=DR/2.0,H=rebar_length,O=0).rotateX(90).translate((r_x_shift, r_y_shift, r_z_shift))
rebar_bend=ARC3D(s,D=DR/2.0,R=RR,A=90).rotateX(90).rotateZ(90).translate((r_x_shift, r_y_shift_bend, r_z_shift))
rebar.uniteWith(rebar_bend)
rebar_bend.erase()
rebar_top = CYLINDER(s,R=DR/2.0,H=rebar_top_height,O=0).translate((r_x_shift, r_y_shift_bend, r_z_shift + RR))
rebar.uniteWith(rebar_top)
rebar_top.erase()
beam.uniteWith(rebar)
rebar.erase()
# Region Configure Port Configuration and Grips #
s.setLinearDimension('L', (0, 0, b_z_shift), (0, L, b_z_shift))
s.setPoint(port, (1, 0, 0))
