Instrument symbology not working
antonio_oliveiraG63JM
I needed to use a certain type of symbology representation for isometric, but it didn't work. I need to apply the magenta model with a circle, but my project only shows the rectangular model in yellow, how can I display the circular model or add it?
Non-functional project:
Functional design:
DVaquand
Hello @antonio_oliveiraG63JM
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Thank you for your help, but I believe there was a mistake in my explanation. What I do not have is access to the circular symbol for representing instruments, the current project only has the rectangular presentation, I would like to know how I can add or activate the circular symbology model which I do not have access to in the project.
DVaquand
In your "IsoSkeyAcadBlockMap.xml" file you should see which block (iso symbol) is called from the SKEY code "IDFL"
Perhaps create a new SKEY code associated with an iso symbol that suits you.
<!-- Begin: Instrument symbols -->
<SkeyMap SKEY="ITFL" AcadBlock="Instrument-Tee"/>
<SkeyMap SKEY="IDFL" AcadBlock="Instrument-Offline-FL"/>
<SkeyMap SKEY="ID??" AcadBlock="Instrument-Offline"/>
<SkeyMap SKEY="II??" AcadBlock="Instrument-Inline"/>
== French ==
Dans votre fichier "IsoSkeyAcadBlockMap.xml" il faudrait voir quel bloc (symbole iso) est appellé depuis le code SKEY "IDFL"
Peut être créer un nouveau code SKEY associé à un symbole iso qui vous conviendrez.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Thanks for the support!
