HOW TO REMOVE OLD LINE NUMBER
Mdelaney_Jr
Message 1 of 9
Mdelaney_Jr
When creating an ISO from the model I use the pipe routing that allows you to assign a line identifier. The problem I have is if I no longer need that pipeline I can remove the identifier from the layer drop-down but not the dropdown list that is created in the pipe routing element. Can someone show me how to purge these line numbers out once I have deleted the line itself?  (See Pic)
Replies (8)
Message 2 of 9
DACOMA3
Have you tried AUDITPROJECT from the project manager?
Message 3 of 9
Mdelaney_Jr
Thanks, I tried Audit, PLantaudit, and auditproject and they are still attached to the file.
Message 4 of 9
Michiel.Valcke
Have you tried the PnPLocalDataCachePurger.exe ?
You can find it here: C:\Program Files\Autodesk\AutoCAD 20xx\PLNT3D
Make sure to close Plant 3D before running it.
Message 5 of 9
Mdelaney_Jr
Thanks, I will work on this and get back to you if it worked or not.
Message 6 of 9
Ray_K
Try Using
auditproject and compressproject
Message 7 of 9
Mdelaney_Jr
I've tried all, and the line is still showing. Can someone use the Route Pipe Function by assigning a line number, size, and spec to a line, then delete the line, purge the line info (PU), then see if you still see the line in the Route Pipe dropdown. See pic @Ray_K @Michiel.Valcke @DACOMA3
Message 8 of 9
Michiel.Valcke
If the purge is not helping then I suppose there must still be objects left in your drawing that have the old line numbers. Most likely they'll be fasteners that weren't selected when changing the line numbers the first time.
You can use the datamanager to find them.
Message 9 of 9
Mdelaney_Jr
@Michiel.Valcke
Thanks, I will work on this and see if this resolves my issue.
