AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to measure accuratly in Navisworks for P3D model which is in State Plane Coordinates...
2 REPLIES 2
354 Views, 2 Replies
I am searching for a way to get the XYZ for dimensioning to follow the model.  I have tried rotating the UCS and the XYZ in Navis but the measurement is still incorrect orientation.  We need this so our laser scans from the Trimble will be correctly overlaid with the P3D model.
2 REPLIES 2
h_eger
Dear @Anonymous ,
why so complicated?
The laser scan should be created with reference to your Plant 3D coordinates, otherwise the subsequent work can hardly be grasped in time.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
The P3D coordinate will match the State Plane Coordinates.  So if I set my model to those which may be rotated 45deg, then how can I get Navisworks to read that so when I measure, I get correct XYZ vs what I showed in the attachment.
