HOW TO LINK DATA FROM JSON FILE TO PYTHON
traiduong014969
traiduong014969
Hello everybody,
I'm having trouble connecting a JSON file to Python. I'm currently making a custom valve with numerous parameters. I created a JSON file and added parameters to it to reduce the number of parameters. But it's not working. You can see code from JSON and python.
Someone can help me fix that.
Thank  you!
    "1": { "D": 8.625, "L": 15.0, "H": 8.625 },
    "2": { "D": 10.625, "L": 25.0, "H": 10.625 },
    "3": { "D": 12.0, "L": 36.0, "H": 12.0 }
from aqa.math import *
from varmain.primitiv import *
from varmain.var_basic import *
from varmain.custom import *
import json
import os
import sys
sys.path.append(os.path.normpath(sys.PnP3dNativeContentCustomScriptsPath))
class Test_Valve_Modeler:
    def __init__(self, SpecParams, **kw):
        # Parameters from the spec
        self.s = SpecParams['s']
        self.tag = SpecParams.get('TAG', 1)
        self.specKw = SpecParams['specKw']
    def build_model(self):
        try:
            self.set_values()
            self.build_valve()
        except Exception as e:
            print(f"Error: {e}")
            raise
    def set_values(self):
        with open('json1.json', mode='r') as file:
            data = json.load(file)
        part_params = data.get(str(self.tag), {})
        D = part_params.get('D', 0.0)
        L = part_params.get('L', 0.0)
        H = part_params.get('H', 0.0)
        self.OD = D
        self.L = L
        self.H = H
        print(f"D: {D}, L: {L}, H: {H}")  # Print values for debugging
    def build_valve(self):
        try:
            oC1 = CONE(self.s, R1=self.H / 2, R2=0, H=self.L / 2)
            oC1.rotateY(90)
            oC2 = CONE(self.s, R1=self.H / 2, R2=0, H=self.L / 2)
            oC2.rotateY(-90).translate((self.L, 0, 0))
            oC3 = self.build_wheel()
            oC3.translate((self.L * 0.5, 0.0, 0.0))
            oC1.uniteWith(oC2)
            oC2.erase()
            oC1.uniteWith(oC3)
            oC3.erase()
            self.s.setPoint((0, 0, 0), (-1, 0, 0))
            self.s.setPoint((self.L, 0, 0), (1, 0, 0))
            print(f"Valve Error: {e}")
            raise
    def build_wheel(self):
        try:
            R1 = self.OD / 30
            R2 = self.OD / 40
            R3 = self.OD / 2 - R1
            self.L = self.L - R1
            oT0 = TORUS(self.s, R1=R3, R2=R1).translate((0, 0, self.L))
            oC1 = CYLINDER(self.s, R=R2, H=R3 * 2, O=0).rotateX(90).translate((0, R3, self.L)).rotateZ(45)
            oC2 = CYLINDER(self.s, R=R2, H=R3 * 2, O=0).rotateY(90).translate((-R3, 0, self.L)).rotateZ(45)
            oC3 = CYLINDER(self.s, R=R2, H=self.L, O=0)
            oC1.uniteWith(oC2)
            oC2.erase()
            oC1.uniteWith(oC3)
            oC3.erase()
            oC1.uniteWith(oT0)
            oT0.erase()
            return oC1
            print(f"Wheel Error: {e}")
            raise
@activate(Group='Valve, ValveBody', TooltipShort='TestValve', TooltipLong='TestValve', LengthUnit='in', Ports='2')
@group('MainDimensions')
@param(TAG=ENUM, TooltipLong='1, 2, 3')
@enum(1, 'ValveTag1')
@enum(2, 'ValveTag2')
@enum(3, 'ValveTag3')
def TestValve(s, TAG=1, **kw):
    try:
        spec_params = {'s': s, 'TAG': TAG, 'specKw': kw}
        valve = Test_Valve_Modeler(spec_params, **kw)
        valve.build_model()
    except Exception:
        print("Failed to build a valve")
so
matt.worland
You were pretty close with reading the data. Using the below method works for me.
    try:
        with open(r"C:\AutoCAD Plant 3D 2024 Content\CPak Common\CustomScripts\test_valve.json", mode='r') as file:
        part_params = data[str(self.tag)]
        self.OD = D
        self.L = L
        self.H = H
        print(f"Set Valve Error: {e}")
        raise
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
traiduong014969
Thank for your reply.
Yes, I just tested it, and it works. So I have an issue:
Your solution works when the path is right with the AutoCad version. However, with the AutoCad version lower, This file will not work. So there's another way it's compatible with most versions?
matt.worland
You should be able to put that file anywhere you would like, as long as Python in P3D has access to its location in here sys.path
traiduong014969
Thank you matt.worland for help. It's working for me
