How to keep the objects selected in AutoCAD Plant3D drawings while executing a command with .NET
vaishnavi_agrawalSJ2Y6
I've written a command method to perform some operation on the object selected in current drawing.
To obtain the object selected in current drawing I am using the API Editor.GetSelection() with the command flag UsePickSet to get the object already selected by user in the drawing. But I observed that when the command is executed the object gets deselected.
I want the object to remain selected even after the execution of command. Is there a way this can be achieved via .NET?
I've already tried the solution provided in the above link, but it does not work with the command flag UsePickSet.
When this command flag is not used, user has to select the object after calling the command, and then this selection works. But in my case I want user to first select the object in drawing and then call the command. The API should be able to obtain the object already selected in drawing and then proceed with the operation and leave the object selected.
Is there any way both can be achieved?
jabowabo
Try adding the Redraw command flag and a regen after setting the implied selection. This works for me:
        [CommandMethod("TestMoveItems", CommandFlags.UsePickSet | CommandFlags.Redraw)]
        public static void TestMoveItems()
            // get your editor (this is custom - use your normal method)
            Editor ed = Active.Ed;
            // get user selected items
            PromptSelectionResult selPrompt = ed.GetSelection();
            if (selPrompt.Status != PromptStatus.OK)
                return;
            // do something with items (this is a custom method - use your own code here)
            ModifyTools.MoveObjects(Point3d.Origin, new Point3d(10, 10, 10), selPrompt.Value.GetObjectIds().ToList());
            // finally, set items as selected
            ed.SetImpliedSelection(selPrompt.Value.GetObjectIds());
            ed.Regen();
The above solution works perfectly. Thanks!
theshoaib.mughal
This works wonders with -
PromptSelectionResult psr = ed.GetSelection();
but what about -
PromptEntityResult = ed.GetEntity();
How can we achieve that?
I have tried this -
[CommandMethod("EntityTest", CommandFlags.UsePickSet)]
public static void EntityTest()
	Document doc = AcadApp.DocumentManager.MdiActiveDocument;
	Database db = doc.Database;
	Editor ed = doc.Editor;
	try
		PromptEntityOptions peo = new PromptEntityOptions("\nSelect Straight Tray Section: ");
		PromptEntityResult per = ed.GetEntity(peo);
		if (per.Status != PromptStatus.OK) return;
		//My Code here
		ed.SetImpliedSelection(new ObjectId[] { per.ObjectId });
	catch (System.Exception ex)
		if (!string.IsNullOrEmpty(ex.Message)) ed.WriteMessage($"\n{ex.Message}");
But it doesn't work. Any help
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
