AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to insert new spec to existing project in modeling ?
4 REPLIES 4
sarsivi30993
995 Views, 4 Replies
Dear All,
I have created a spec.  Now I am trying to insert on my existing project but I can do it only for new project and not on existing project.
Please let me know the procedure to insert on existing project.
Please provide the information since I am running short of time.
Anticipating your valuable response
Thanks.
4 REPLIES 4
Just copy the Spec to the folder that you've specified in the project properties
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Thanks for your quick reply,
The below is project location and I have checked in it.  But I cannot find spec file that I used in modelling.
Let me know if I am looking in correct path or not ?
Also please brief me on this to have clear understanding.
\\xxxxxxxx\projects\18520-xxxxx\WORKING\SARSIVIRAMAN\AutoCAD Plant 3D\Project\Sample\Spec Sheets
Thank you
Copy the spec into that folder and restart Plant3D if you're already in it when you copy it. Then it'll appear.
Tomislav Golubovic
Autodesk, Inc.
in reply to: TomislavGolubovic
If it dosn't appear after copying and closing P3D the reopening - righ click mouse to add spec at this location and select add spec - locate path - then it comes in  spec.JPG
I have a question I have created a new spec. and all is well except that my component size selection dosn't not come in - yet if I place it into an existing spec it will work. please help.
Technology Administrators
AutoCAD Beta
