Well im still new with the software and slowly learning using the autocad plant. Here my problem, where do i find the agitator? and how can i put the agitator into the tank?
If you're using the PIP standard its on the Equipment Palette, down the very bottom.
Iso you're on the ISO standard, its on the Equipment Palette, 6th section down
On the ISA standard, its on the Equipment Palette, 7th section down
On the JIS standard, its on the Equipment Palette, 10th section down.
I can't see one on the DIN standard.
