AutoCAD Plant 3D Forum
how to insert agitator
1 REPLY 1
532 Views, 1 Reply
Well im still new with the software and slowly learning using the autocad plant. Here my problem, where do i find the agitator? and how can i put the agitator into the tank?
1 REPLY 1
TomislavGolubovic
If you're using the PIP standard its on the Equipment Palette, down the very bottom.
Iso you're on the ISO standard, its on the Equipment Palette, 6th section down
On the ISA standard, its on the Equipment Palette, 7th section down
On the JIS standard, its on the Equipment Palette, 10th section down.
I can't see one on the DIN standard.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
”Boost
