How to get objectId of ports in Valve with NET
traiduong014969
traiduong014969
Hi all,
I have a problem getting information about ports in a valve. I can get the number of ports, but I cannot retrieve the values for each port individually. All ports have the same value.
For example, I have a valve with Port S1 facing RF and Port 2 facing WF. However, when I execute the command, it only shows information for one port.
public static void GetValvePorts()
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    Database db = Application.DocumentManager.MdiActiveDocument.Database;
    using (Transaction tr = db.TransactionManager.StartTransaction())
        try
            Project currentProject = PlantApplication.CurrentProject.ProjectParts["Piping"];
            DataLinksManager dataLinksManager = currentProject.DataLinksManager;
            if (dataLinksManager == null)
                ed.WriteMessage("\n❌ DataLinksManager.");
                return;
            PromptEntityResult res = ed.GetEntity("\nselect valve: ");
            if (res.Status != PromptStatus.OK) return;
            ObjectId valveId = res.ObjectId;
            Autodesk.ProcessPower.PnP3dObjects.Part valve = tr.GetObject(valveId, OpenMode.ForRead) as Autodesk.ProcessPower.PnP3dObjects.Part;
            if (valve == null)
                ed.WriteMessage("\n❌ .");
                return;
            Autodesk.ProcessPower.PnP3dObjects.PortCollection portColl = valve.GetPorts(PortType.All);
            if (portColl == null || portColl.Count == 0)
                return;
            ed.WriteMessage($"\n📌 Valve has {portColl.Count} Port:");
            foreach (Port port in portColl)
                ed.WriteMessage($"\n🔹 Port: {port.Name}");
                ObjectId portObjId = valveId; //
                StringCollection propNames = new StringCollection { "Facing", "EndType", "PressureClass" };
                StringCollection propValues = dataLinksManager.GetProperties(portObjId, propNames, true);
                if (propValues.Count == propNames.Count)
                    ed.WriteMessage($"\n   - Facing: {propValues[0]}");
                    ed.WriteMessage($"\n   - EndType: {propValues[1]}");
                    ed.WriteMessage($"\n   - PressureClass: {propValues[2]}\n");
                else
                    ed.WriteMessage("\n   ⚠️ .\n");
            tr.Commit();
        catch (System.Exception ex)
            ed.WriteMessage("\n❌ error: " + ex.Message);
Replies (8)
jabowabo
traiduong014969
Yes, I don’t know the ObjectId of the ports in the valve. So, I temporarily replaced it with the ObjectId of the valve for coding purposes. Now, I want to get the ObjectId of the valve ports to ensure the code works correctly. Could you help me fix this issue?
Thank you !
jabowabo
Ports don't have an OID. You'll need to get the RowId of the ports (other than port 1) and retrieve the properties that way.
traiduong014969
this may code , but it not work
  int portRowId = dataLinksManager.FindAcPpRowId(dataLinksManager.MakeAcPpObjectId(port));
jabowabo
As stated before, ports don't have ObjectId, so this code will not work. You need to start with the owning part rowId and get the related port row ids.
DataLinksManager.GetRelatedRowIds("PartPort", "Part", partRowId, "Port")
traiduong014969
i try like this . I cant find all port but i cant get information for whole valve port
public static void GetValvePortsDebug()
        try
            if (currentProject == null)
                return;
                return;
            PromptEntityOptions peo = new PromptEntityOptions("\nselect valve: ");
            peo.SetRejectMessage("\n none ob p3d.");
            peo.AddAllowedClass(typeof(Autodesk.ProcessPower.PnP3dObjects.PipeInlineAsset), true);
            PromptEntityResult res = ed.GetEntity(peo);
            if (valve == null)
                return;
            int partRowId = dataLinksManager.FindAcPpRowId(valveId);
            if (partRowId == -1)
                return;
                return;
            ed.WriteMessage($"\n📌 Van (ID: {valveId}, RowId: {partRowId}) có {portColl.Count} Port:");
            PnPRowIdArray allPortRowIds = dataLinksManager.GetRelatedRowIds("PartPort", "Part", partRowId, "Port");
            if (allPortRowIds == null || allPortRowIds.Count == 0)
                return;
            ed.WriteMessage("\n🔍 Debug: :");
            Dictionary<string, int> portRowIdMap = new Dictionary<string, int>();
            foreach (int portRowId in allPortRowIds)
                StringCollection propNames = new StringCollection { "PortName" };
                StringCollection propValues = dataLinksManager.GetProperties(portRowId, propNames, true);
                if (propValues != null && propValues.Count > 0)
                    portRowIdMap[propValues[0]] = portRowId;
                    ed.WriteMessage($"\n   - PortName: {propValues[0]}, RowId: {portRowId}");
            StringCollection propNamesForPorts = new StringCollection { "Facing", "EndType", "PressureClass", "NominalDiameter" };
            foreach (Autodesk.ProcessPower.PnP3dObjects.Port port in portColl)
                if (!portRowIdMap.TryGetValue(port.Name, out int portRowId))
                    ed.WriteMessage($"\n   ⚠️  '{port.Name}'.");
                    continue;
                ed.WriteMessage($"\n🔍  '{port.Name}' (RowId: {portRowId})...");
                StringCollection propValues = dataLinksManager.GetProperties(portRowId, propNamesForPorts, true);
                if (propValues != null && propValues.Count == propNamesForPorts.Count)
                    ed.WriteMessage($"\n   - Facing: {(string.IsNullOrEmpty(propValues[0]) ? "[None]" : propValues[0])}");
                    ed.WriteMessage($"\n   - EndType: {(string.IsNullOrEmpty(propValues[1]) ? "[None]" : propValues[1])}");
                    ed.WriteMessage($"\n   - PressureClass: {(string.IsNullOrEmpty(propValues[2]) ? "[None]" : propValues[2])}");
                    ed.WriteMessage($"\n   - NominalDiameter: {(string.IsNullOrEmpty(propValues[3]) ? "[None]" : propValues[3])}\n");
                else
            ed.WriteMessage($"\n❌ Lỗi: {ex.Message}\n{ex.StackTrace}");
traiduong014969
when i tested code, valve that i selected almost get the same value for rowid. With the same value, i dont know that is the reason  i cant find information  Port
jabowabo
Post the code that you used to get this result.sssssssssssssssssss
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
