Hi forum
Im looking for some feedback to fix this
I need to export a 3d file to dwf keeping the object´s tag on the dwf format
If exist some solution, i will be appreciate if somebody can to share it with me
Hi phwatso,
Thanx for your comment.
Yes, I used it.
Please, check my attachted files bellow.
dwf-tag-2: is a p3d model´s view
dwf-tag-1: is a naviswork´s view
Thanx!
Actually, I checked on Design Review 2010...and they are there (Object´s tags)
Hi Alex,
Thank you so much for your message.
Yes....i still having this inconvenience. Could do you help me?
Hi Pablo,
I think your issue has been solved in a separate forum post. I have attached the link below.
You just want to make sure you have the Navisworks export utility downloaded and the Plant 3D object enablers. The object enablers should be the same version as the Navisworks program you have installed. The export utility will allow you to use the NWCOUT command within Plant 3D, to export the file to Navisworks.
Navisworks forum post link here
Please hit the Accept as Solution button if my post resolves your issue
