How to create thicken for pipe in catalogue with custom script ?
traiduong014969
traiduong014969
Dear all,
In the default catalogue. I see have OF parameter, I will try another number to create thicken for pipe. However, I see it's not change thicken of pipe. I want to pipe with thicken that has change length like to default pipe. So someone can help me edit  scrip default pipe and share for me. In the default script, it only see the file with .xml format default. I do not see and edit for .py format which I can edit for my custom pipe.
This is the link to file has xml format for pipe: C:\AutoCAD Plant 3D 2021 Content\CPak Common\metadata\varmain\pipesub
I really appreciate it !
rajendra.prajapat
@traiduong014969 you can do it by python script with fixed length pipe along with thickness.but if you want to stretch the pipe like plant 3d default then it is not possible.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
