How to correctly show a isometric symbol according to its connection type
rjansen2020
rjansen2020
Does anyone know how you can manipulate the direction of an isometric symbol. I have tube fitting symbol at each side of a Female valve. on the ISO they are shown in the same direction in stead of opposite directions. (see attachment)
DVaquand
Hello @rjansen2020
How were the ports on the isometric symbol created?
In which 3D class was the 3D component defined?
== French ==
Comment ont été créé les ports sur le symbole isométrique ?
Dans quelle classe 3D a été définie le composant 3D ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
h_eger
@rjansen2020 ,
Have you also entered your iso symbol in the "IsoSkeyAcadBlockMap.xml" under the "ASYMMETRIC COMPONENT LIST" section?
Please note that the EndType may only have 2 digits
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
rjansen2020
Yes it works.
Thank you: h-eger
You mentioned that the Endtype has to be 2 Digits. Endtype1 was "THDM" and endtype2 was "PL". So all the symbols where placed in the wrong direction. After I switch the two endtypes it worked perfectly.
For those who has the same problem: to switch those I did the following:
I use a custom AutoCAD DWG Block based component in Plant 3D.
- In the DWG with the blocks I used the command PLANTPARTCONVERT to deleted Port1 and Port2 of the block and reassigned Port 1 (=PL) and 2 (=THDM)
- In the catalog Editor of the Spec Editor I changed the endtypes of the component.
- In the AcadBlock "TubeAdapterStraighMale" I also switched Port1 and Port2
- In the project drawing I updated the spec and model of the component
In IsoSkeyAcadBlockMap.xml I had the LINE
<SkeyMap SKEY="TASM" AcadBlock="TubeAdapterStraighMale" />
I added  in the ASYMMETRIC COMPONENT LIST section:
<AsymmetricComponent Type="COUPLING" Skey="TASM" EndType="PL" />
