Dear forum members
I am trying to connect a valve with slope to a nozzle on a tank but i get the error "the ports must be adjacent in order to connect"
I already modified the DefaultConnectorsConfig but without any luck
What do i need to alter for this to work?
The slope is 1:40 so not really that big
In these situations I move the valve out so nothing is connected to it and then grab one of the end grips and snap it back into the line. This will automatically align it to the pipe it is connecting to.
@Anonymous
Placing a valve in a pipe is no issue at all
Placing it agains a tank nozzle is a different story
Oh I see. In that situation I would either have the valve square to the nozzle with the piping then having the fall away from the valve, or have a custom nozzle that has the fall built into it.
With a reasonable slope of 1:40 then I would go with the custom nozzle as that is what they would likely have to do when fabricating it.
@Anonymous
Thanks for your advise
It seems better to also place the tank nozzle under the needed slope
