How to change the default normally selection list programmatically
This widget could not be displayed.
How can I change the default selection list for the Normally property programmatically through P&ID .NET API? I want to do what is described here
Thanks!
h_eger
Dear @Anonymous ,
how well do you know the program structure of Plant PuID?
The property "Normally" is only an extended exchange function before the symbols must be applied in the respective class. After this is done, the respective symbols can be assigned via the normal function.
The .NET API makes it more of a challenge to work through these complex steps through your program.
Here you can try it once to find a solution to your problem.
https://adndevblog.typepad.com/.services/blog/6a0167607c2431970b0162ffdc445e970d/search?filter.q=Plant
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
