How to add Multiple nozzle into equipment with python script
traiduong014969
Message 1 of 10
traiduong014969
Hi all, recently I have created equipment with python. I successfully with creating equipment with nozzle fixed. However, when I create any nozzle such as a tank, or vessel. It appears as a snapshot below. Someone can help me fix that.
As always thank you for your time and consideration. Have a GREAT day!
Replies (9)
Message 2 of 10
rajendra.prajapat
@traiduong014969 Please try below lines
<Nozzles>
<NozzleInfo Name="Nozzle 1" PortIndex="1">
<DisplayName>Nozzle 1</DisplayName>
<NozzleTypes />
<Parameters>
<ParameterInfo Name="LOC" DefaultValue="1" Type="List" />
<ParameterInfo Name="R" DefaultValue="0" Type="d0" />
<ParameterInfo Name="A" DefaultValue="0" Type="a" />
<ParameterInfo Name="L" DefaultValue="3" Type="d" />
</Parameters>
<PortProperties>
<PropertyInfo Name=".SizeRecordId" DefaultValue="4b77a031-115e-53ce-affc-6aa39b8177f1" />
</PortProperties>
</NozzleInfo>
<NozzleInfo Name="Nozzle 2" PortIndex="2">
<DisplayName>Nozzle 2</DisplayName>
<NozzleTypes />
<Parameters>
<ParameterInfo Name="LOC" DefaultValue="2" Type="List" />
<ParameterInfo Name="H" DefaultValue="45" Type="d-" />
</Parameters>
<PortProperties>
</PortProperties>
</NozzleInfo>
</Nozzles>
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 3 of 10
traiduong014969
Yes, I'm tried add your code, but it not working. You can see picture below:
This is my code
Message 4 of 10
rajendra.prajapat
@traiduong014969 please do not use the same GUID.
Message 5 of 10
traiduong014969
yes, follow your guide, I replaced GUID. it appears a message warning and then I click ok, equipment insert is a tank that has torispherheads . actually, in my code, I only insert a cylinder. and then i don't  create an new when-click button to make an equipment
Message 6 of 10
rajendra.prajapat
@traiduong014969 please attached the equipment package here.
Message 7 of 10
traiduong014969
this is my code when i update GUID
Message 8 of 10
rajendra.prajapat
@traiduong014969 you need to define the used equipment parameter in python script  inside the equipment xml file.
Message 9 of 10
traiduong014969
you can share an example code for me, please
Message 10 of 10
rajendra.prajapat
@traiduong014969
<PartProperties>
<PropertyInfo Name="PartSizeLongDesc" DefaultValue="Electrical Panel" />
</PartProperties>
<Categories>
<CategoryInfo Name="EPANEL">
<Parameters>
<ParameterInfo Name="D" DefaultValue="500" />
<ParameterInfo Name="W" DefaultValue="250" />
<ParameterInfo Name="H" DefaultValue="1000" />
</Parameters>
</CategoryInfo>
</Categories>
script code
def EPANEL(s, D = 500.0, W = 250.0, H = 1000.0, ID = 'EPANEL', **kw):
a1 = EQBOX(s, D = D, W = W, H = H)
s.setPoint((0, 0, 0), (0, 0, -1))
s.setPoint((0, 0, H), (0, 0, 1))
