How to add custom attribute property in iso sheet continuation (to) & (from) for iso annotation
dharunkumar.am
dharunkumar.am
is there any way to add custom attribute in " iso sheet continuation (to) " and " iso sheet continuation (from) "
The "add property" seems to be not working in this section
h_eger
Dear @dharunkumar.am ,
Enclosed is the section from IsoConfig.xml where you can set this up.
        <!-- Enable only end-connection or end-position annotations -->
        <AnnotationSchemes>
          <EndConnectionScheme Name="EndConnectionsEquipment" AnnotationStyle="Standard" Format="CONNECTED TO\P{0}\P{1}" LeaderStyle="AlwaysCorner" Filter="EndConnectionsEquipment" Fields="CONNECTION-REFERENCE CO-ORDS" DefaultsOverride="true" />
          <EndConnectionScheme Name="EndConnectionsPipe" AnnotationStyle="Standard" Format="CONT'D ON\P{0}\P{1}" LeaderStyle="AlwaysCorner" Filter="EndConnectionsPipe" Fields="PIPELINE-REFERENCE CO-ORDS" DefaultsOverride="true" />
          <EndConnectionScheme Name="EndConnectionsOpen" AnnotationStyle="Standard" Format="OPEN END\P{0}" LeaderStyle="AlwaysCorner" Filter="EndConnectonsOpen" Fields="CO-ORDS" />
          <EndConnectionScheme Name="EndConnectionsClose" AnnotationStyle="Standard" Format="CLOSED\P{0}" LeaderStyle="AlwaysCorner" Filter="EndConnectionsClosed" Fields="CO-ORDS" />
          <EndConnectionScheme Name="EndConnectionsVent" AnnotationStyle="Standard" Format="VENT\P" Enabled="false" LeaderStyle="AlwaysCorner" Filter="EndConnectionsVent" Fields="" />
          <EndConnectionScheme Name="EndConnectionsDrain" AnnotationStyle="Standard" Format="DRAIN\P" Enabled="false" Filter="EndConnectionsDrain" Fields="" />
          <EndConnectionScheme Name="EndConnectionsTo" AnnotationStyle="Standard" Format="CONT'D ON\PDWG# {0}\P{1}" LeaderStyle="AlwaysCorner" Filter="EndConnectionsToRefNotNull" Fields="REFERENCE-TO CO-ORDS" />
          <EndConnectionScheme Name="EndConnectionsFrom" AnnotationStyle="Standard" Format="CONT'D FROM\PDWG# {0}\P{1}" LeaderStyle="AlwaysCorner" Filter="EndConnectionsFromRefNotNull" Fields="REFERENCE-FROM CO-ORDS" />
        </AnnotationSchemes>
      </Annotations>
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
dharunkumar.am
I added the field using iso config file . But the value is not populating in dwg . Do i need to make any changes to the code .
h_eger
You wrote about customer attributes and not about hard-coded attributes like "PIPELINE-REFERENCE".
Unfortunately, this does not work.
Hartmut Eger
Senior Engineer
XING | LinkedIn
dharunkumar.am
Is there any way to get "line tag number" there by any means ?
