How can I import / copy a list from Project setup between two existing project?
chantal.gagne
chantal.gagne
I'm trying to copy/import some list from an existing project to an another existing project.
Can you help me?  It is possible to do this?
I'm working in Pipe line group.
Picture : list example
Artem_Marinin
Hi @chantal.gagne
It's possible by add-in which is called PlantExpressTools by Auxalia (ex-CadStudio).
In plain Plant3D you should recreate lists in project settings.
Best Regards,
Artem Marinin
h_eger
if you can still wait for the next version of Plant 3D then this problem is solved.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
