Help with Report Creator
wayne.oglesby
Message 1 of 13
wayne.oglesby
I have just started working with Report Creator  in Plant 2019 and have not figured out how to set it up.  I have read several different posts and still don't grasp how to set up what I am trying to do.  I just need a simple bill of materials listing the total quantities of my different fitting and total length of pipe all separated by size.  When I ran my query, it appears to have around 9000 pages of components.  I am using the ASME BPE class for my plant and will have Tri-Clamp and butt weld connections on the different components.  If anyone could point me in the right direction, it would be greatly appreciated.
Replies (12)
Message 2 of 13
Tomislav.Golubovic
In the Report Creator first dialog box, select "3D Parts" as the Configuration you want, and then click "Edit"
In that second window, make sure the output type is One report / project. It sounds like you have it set to One report / object.
Message 3 of 13
wayne.oglesby
Tomislav,
  Thanks for the reply, but I checked and it is set to one report for project.  My problem is it is not summing up the individual parts.  It is creating a separate line for each item.
Message 4 of 13
Tomislav.Golubovic
And you didn't change the report in any way?
Message 5 of 13
wayne.oglesby
The only thing I changed was to add elbow, tee side outlet, reducer and pipe to the class name in the query.  For a filter I put ='ASME BPE' .   When I tested the query result, it worked.   I haven't changed anything in the actual report layout as I was attempting this for the first time and wasn't sure about that.  I'm very much a rookie on this part.
Message 6 of 13
jabowabo
Make sure your sort fields are correct in layout editor - you should generally only have sort fields for your report columns (except Quantity). You shouldn't have any sorts for part-unique fields like PnPID, ItemCode, etc.
They shouldn't look like mine but you can find them here:
Message 7 of 13
wayne.oglesby
It's better following your instructions, I am at least getting it sorted the way I want it, but it still isn't summing all of the parts on one sheet. attached is what I'm getting. I know I'm just missing a step, but I don't have a clue what it is.report 1.PNGreport2.PNG
Message 8 of 13
jabowabo
You've got your items under a 'Detail' band rather than a 'GroupHeader' band. I think you at least need to change this.
Message 9 of 13
wayne.oglesby
Jason,
  I just put everything in group 1 and had the same result when I went to print preview.  I'm at a loss as to what I am doing wrong.  I am missing some format that needs to be included.  It is not listing pipe lengths for the pipe, just listing the individual pipe diameters.  I just can't figure out how to get this to sum up the parts and the total length of the different pipe sizes.  I appreciate all of your help.
Message 10 of 13
I worked a lot with the report designer tutorial and some tutorials from PDO-Team. This helped me a lot to understand how the reportCreator is working.
https://knowledge.autodesk.com/support/autocad-pid/learn-explore/caas/sfdcarticles/sfdcarticles/Auto...
http://www.pdoteam.com/?s=report
Hope this helps you too.
greetings Patrick
Message 11 of 13
wayne.oglesby
Thank you Patrick, I was not able to find this guide before.  I will read through this and see if I can get this report to work.
Message 12 of 13
jabowabo
Also check these settings:
Message 13 of 13
wayne.oglesby
Thank you very much Jason
