Help! All pipe tags missing from the P&ID
dunja_mitrovic
dunja_mitrovic
Hi everyone,
I apologize if this theme was already posted somewhere, but it seems that I cannot find the answer to my problem.
I have been using Plant 3D for some time now and I have been working on a project with 190 drawings. I have been working on some of these drawings, and suddenly when I changed info on one of the off page connectors, I notice that the pipe tag has gone. I tried to assign it again, but it just keeps disappearing. I exited the program since I thought it was some kind of bug and when I opened the project again, in every drawing that I checked I got the message that some of the tags need updating and all of the pipe tags are gone.
If I just click review later, I can keep my tags, but how can I make sure that they are permanently back in the project and database? I don't understand how this happened and why all the pipes lost connection.
Thank you for the help in advance
h_eger
@dunja_mitrovic ,
I can't really help you with this as I don't have the background information on your project constructors. But it looks like you already have objects in your project that have lost a connection to the database. This can lead to further failures and data loss.
P3D version
Storage location - Local - Network - ACC
Local SQ-Lite or SQL Server DB
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
dunja_mitrovic
@h_eger
Hi, I am sorry I didn't provide enough information.
So the version of P3D I'm using is 16.0.58.1009
When I check the Project Setup, it is set to SQLite local database.
I need to add that I am usually connected to my work LAN network, but now when this happened I was working from home and I wasn't connected to this network. One additional thing which also contributed to the situation is that I am first time working from a new laptop, but the project I'm working on is on the company server.
All the valve and equipment tags are still on the drawing and what additionally confuses me is that I worked normally and made changes on 4 of the drawings, made a quick break and when I came back and started fixing the 5th drawing this problem occurred.
Is there a way to reconnect data base for the pipes?
h_eger
@dunja_mitrovic ,
if the P&ID's are disconnected from the database I know of no way to repair this. In the last 15 years I have not yet succeeded.
The separate working method from the home office and the office is not quite as good, but if the arrangements with colleagues work out, it should be solvable.
Can you ask your IT department whether it is possible to work on the project in the office via VPN from your home office?
Otherwise, I can only recommend backing up your project at least once a day so that you don't lose too much work if problems occur.
One more question about your laptop, does it go into sleep mode if you don't work on it for a longer period of time?
If so, this can lead to the problems you described as long as Plant 3D is open.
Hartmut Eger
Senior Engineer
XING | LinkedIn
dunja_mitrovic
@h_eger I think this is exactly what happened, the PC went to sleep. I didn't think that this could cause such a problem.
I have one additional question. I do have backup from some time ago, in the meantime there were changes made on some of the P&ID.
Is it possible that I use the backup copy, but to add the drawings from the current version and fix the pipe tags manually on the drawings that were changed?
Or do I need to redo all the changes I made in the backup version?
h_eger
@dunja_mitrovic ,
If you delete the defective drawing from the project, the changes will also be lost. Unfortunately, you will have to add the changes to the backup copy after you have copied it back into your project.
Hartmut Eger
Senior Engineer
XING | LinkedIn
dunja_mitrovic
@h_eger Thank you very much for the help!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
