Geometry can not be generated with the given parameters.
jshubin
jshubin
Changing the L1 or L2 lengths of a 26" 5D pipe bend produces the error "Geometry can not be generated with the given parameters."
How do I correct this issue?
Check the radius value, and the arc length and make sure your using the correct dimensional charts.
jshubin
45°, Bend Radius 3302 mm (correct for a 26" 5D Bend). Mixed-Metric.
Everything is what it should be .
h_eger
@jshubin,
I can not understand your problem.
It works fine in Plant 3D 2018.1
45 ° Pipebend, radius 3302 mm, L1 and L2 = 300mm
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jshubin
Ran into this issue again and found the solution.
L1 and L2 values must both be entered before enter key. You can not change L1 only,hit enter, then measure your L2 length, change it and hit enter. If L1 or L2 has a value of 0, Plant3D creates error "Geometry can not be generated with the given parameters". BOTH MUST BE DONE TOGETHER. Ridiculous.Smiley Frustrated
