Flanged end pipes
Flanged end pipes
shriram.khanapure
Flanged end pipes
shriram.khanapure
Dear Plant3D experts,
We are creating flanged pipe (PTFE lined) spec for one of our projects.
We created pipe and elbow in spec editor. Please find the below snaps.
We want to fix the pipe length by 3 meters. After 3 meters, it should start new flanged end pipe which is not happening. Also, pipe is not taking flanged end whereas for elbow its showing flanged end. Please find the below snap.
How can we achieve this? Kindly help. thanks..
marcus.reis243UC
I was facing a similar situation, the pipe must have the item in the same spec to add automatically, then you must add a compatible flange to your spec to solve it.
Rolly.Pagod
I believe there is an error on the code of pipe for 2021 up. Version 2020 works fine for the flange pipe.
