Fitting to Fitting Iso Them Dimensions
BSchwartzkopf
BSchwartzkopf
Is there a way to get my iso to show up like picture 1? I currently get picture 2 no matter what theme I turn off or on and no matter what dimensions i turn off or on. Its some variation of pic 2 but never clean like pic 1. There is no reason that pic 2 shouldn't be the same as pic 1 since everything is fitting to fitting with nipples in-between the fittings. I have the fitting to fitting theme turned off. I also tried turning on the fitting to fitting theme but selecting no dimesnions.
Replies (9)
JUANCARLOSBLASCO4129
Hi.
I'm getting fitting-to-fitting theme.
Here my themes setup:
And the iso result, the example is similar than yours:
If your fitting to fitting theme is turned off, of course it's off and doesn't be applied.
If you turn it on but select no dimensions, the dimensions won't be drawn
Enable theme, select display dimension, and select end-to-end removing the other dimension types.
Regards
edit: plant 3d 2018, i don't know with older versions
BSchwartzkopf
This is concerning because I set my settings exactly as yours and I do not achieve the exact same results. Does P3D put options into the GUI that do not actually work? Do they only work if setting them up in the isoconfig.xml? If so why would P3D have options that do not do anything to the settings?
BSchwartzkopf
BTW I am on P3D 2017
I've tried it in 2017 version and works fine, same result as 2018.
I edited this in project set up, haven't changed isoconfig for this purpose.
Have you tried at a default template project?
I'm sorry for not being helpfull
regards
BSchwartzkopf
You are being very helpful. I wonder why it isnt working for me then. Especially when I have everything set to the same settings as you.
BSchwartzkopf
Can you send me a copy of your isoconfig? I could then do a beyond compare with mine and see the differences. If not no big deal.
BSchwartzkopf
I got it to work the same as yours but I had to change the small bore piping theme to match the fitting to fitting theme. It seems the small bore piping is the controlling theme. Is there a way to fix this?
MNeugebauer
Hi @BSchwartzkopf
Your pipes have size 1". In a standard setup there is every size below 2" a small bore pipe.
Small bore pipes have an own layer with the orange colort and also an own annotation theme.
You can change the small bore pipe settings in your project setup -> Annotation. (see my picture attached)
Best regards,
Matthias
BSchwartzkopf
I understand that every pipe under 2" is small bore piping. The only time we will use nipples and fittings together are in small bore piping. This is the area we want to utilize the fitting to fitting theme to clean our drawings up. It makes no sens to dimension to the fittings center-lines when the dimensions are all standard fitting dimensions and cant be changed so the overall is the only dimension needed. If this cant be used in conjunction with small bore piping there is no use for this theme. Is that what you are saying?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
