filename format ISO style setup
smgamal
smgamal
Good day
under project setup / Isometric DWG settings
in (ISO Style setup) , the fields under (FILENAME format)
these attributes reset to the default values each time i open the (title block and display) to edit anything in the ISO template ,
the FILENAME format is not saving any modification i do , so each time i edit he ISO template i have to do the FILENAME format again
check attached screenshot
thanks in advance
George.Endrulat
Can confirm that it happens to us too, or did, we defaulted to service-number-sheet for iso numbers and never looked back. Please don't mark this as a solution, it's not, it's just what we did.
George
If my post offers a solution, please click "Accept as Solution"
smgamal
Well George , after you defaulted to that if you add another attribute it will change back to the default , right ?
SoftFit_Iain
Hi folks,
Did anyone find a fix for this?
I want my filename and dwgname to use a calculated property then indexing suffice, it seems to work for a few iso's then breaks and i get gibberish filenames.
Iain
