Field Fit Weld
Field Fit Weld
MKK20
Field Fit Weld
MKK20
I have managed to get field fit weld at flange "slip-on weld joint" but enable to add markup length in cut length table,I have correctly done makeup length setting also.img_20190709(3).png
Did it add the length to the BOM, not the cut sheet?
MKK20
No makeup length in cutlength table as well as in BOM Qty.
I did the same scenario as you, but was not able to change the slip-on to a FFW. How were you able to change the connector to FFW on the slip-on flange. Trying to duplicate your connectors?
MKK20
You just need to define buttweld as a connector in slipon flange joint or flange joint
