facing issue during import changes in spec editor from excel
rajendra.prajapat
Advisor Advisor
rajendra.prajapat
Dear All @h_eger
I am facing issue during import changes in spec editor from excel. i am not modifying any structure of original file.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
h_eger
@rajendra.prajapat ,
did you export a pipe spec or a catalog?
It looks like you're trying to import a pipe spec in Excel format into the catalog area, or am I mistaken?
What version of the spec editor are you using?
Some Excel bugs have been fixed in P3D 2026.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
rajendra.prajapat
i am importing catalog data. Its working fine in 2023 but not in 24,25 and 26.i think bug from Autodesk side.
h_eger
I tested the entire DIN Valve Catalog with 2026, exported, changed and imported again, and it works as it should without any problems.
Hartmut Eger
Senior Engineer
XING | LinkedIn
CGBenner
@rajendra.prajapat
Can you share some information on how and when this Excel file was created/exported?  Could the file itself have become corrupt?  Thanks!
Chris Benner
