error regarding plant 3d structure
This widget could not be displayed.
We are too much disturbed because of structure generating error.
We have completed all 3D work but When We are exporting the file into AutoCAD that time i saw my Structure is automatic rotate or move.
Please give me solution as soon as possible.
For your referance i am sending you some images.
With Regards,
Actual Channel after using flip option in plant.pngChannel after exporting automatically rotate.png
patpat79
Good day. Just want to ask if the export is direct export via Save As or Copy? (I am considering this structure is from Autocad Plant 3D right?). I only experience automatic movement once, when a I tried to explode a structure component that time, mybe could be related to your problem.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
eadkins73
Which version of plant are you using?
Ed Adkins
EA2 Engineering
www.ea2eng.com
