Error in *.pcf while piping ISO creating
When I go to the sample project and try to create a Quick Iso (the same problem with Production ISO),
I got this error:
And there is no log file generated.
I also have tried all of this styles:
Tried to route pipe with standard spec and create ISO (quick and production) from it.
Also by selection of the pipe from screen.
I also tried generate PCF from pipe and then generate ISO from this PCF.
And each time I get the same result with the same error and without any log file.
The same results for Default project and for custom created project.
Standard specs, standard styles. Output folder by default path:
C:\Users\dko\AppData\Roaming\Autodesk\Autodesk AutoCAD Plant 3D 2023\R24.2\enu\SampleProjects\SampleProject\Isometric\Check_ANSI-B\QuickIsos\Drawings
or to the desktop, downloads, disc F, D...
Every time the same error.
