Hi All,
I currently using Plant 3D 2024.1.1 (update).
We just noticed that some of the Eccentric Reducer Offset annotation are wrong when the reducer it is modeled on N/S orientation, while the E/W orientation is correct. See attached screen shots below with the same line but the other line was rotated 90deg for testing.
I tested the same the same line on Plant 3D 2023, all annotations are correct regardless of the eccentric reducers orientation.
I am not sure if this is a bug. Anyone experience this same problem?
