& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Dear forum members,
Using Plant 3D 2018 having 1 pressure relief valve
Specs of PRV,
Tag --> 3PRV-390
P3D Class --> Valve
Content Iso Symbol Definition --> TYPE=INSTRUMENT-ANGLE,SKEY=RASC
Insulation --> Yes 30 mm thick
Tracing --> Yes Electric
Please see attached screenshot
How to get this PRV to be annotated with only 1 TAG instead of 2?
Thanks in advance
Kind regards
Dear @DGRL,
with very high probability in the ISOCONFIG.XML 2 annotation are configured for instruments.
please check this
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear @h_eger
Can you please point out in which parent i need to be for this?
See attachment
Dear @DGRL,
<ComponentScheme Name="InstrumentTag" AnnotationStyle="WipeCircle" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="Always" Filter="Instrument" Fields="TAG" />
search in your ISOCONFIG.XML for the following entries "InstrumentTag" or similar.
as well as in the lines after Filter = "Instrument" and Fields = "TAG"
so you can find out why your instrument-angle is labeled twice
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dear @h_eger
Thanks for the info
I checked my files and it seems Autodesk changed the behaviour of isosymbols
In 2016 the anglevalve symbole was 1 block
in 2018 they made in from 2 seperate blocks.
I tried to use the 2016 block but it is placed 2 times
Dear @DGRL,
can you please test whether it is a solution in the file "IsoSkeyAcadBlockMap.xml" to change the entry of your Valve Angle as shown.
<SkeyMap SKEY="AR??" AcadBlock="ValveAngle2016" />
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dear @h_eger
This symbol is not being placed correctly in 2018
i already tried this to use.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
