Dear All!
Please! help me,i have stub-in pipe, and i put 1 break point . Then i print out isometric,but the isometric diviced stub-in pipe by 2 parts as picture below.
How can i set up to print out isometric as this picture:
There is no way to do this.
An break point always makes an new isometric.
If you really want to archive this you need to do this manually
Hi @thienthanh81,
define your Iso breakpoint:
Projectconfig->
Isometric DWG Settings->
Iso Style Default Settings
1.) Activate the checkbox "Split drawing on property change".
2.) Add Property "Tie In Number"
3.) activate the check box for "Tie In Number"
Give the Pipe Lines a Tie In Number
Main Pipe Tie In Number 1
Stub In Pipe is Tie In Number 2
And now the Iso's:
What property you used to define an iso break is up to you
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
