AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Delivering Autodesk Plant 3d models towards Bently Autoplant... converting
2 REPLIES 2
ericjdj
591 Views, 2 Replies
Hi there,
I Eric Declemy, work for a piping engineering and construction company.
We work with Autodesk plant 3d for over 7 years now.
At the moment we have a client who wants the "plant3d" models to be delivered in a format for Bently Autoplant.
Is there a way, or method, or a software solution to meet the clients demands?
Please advice....
2 REPLIES 2
h_eger
in reply to: ericjdj
a intelegente Conversion is not possible from Plant 3D to Bentley AutoPLANT.
you can your Plant 3D model in AutoCAD export after Bentley AutoPLANT can import these DWG. There are then only 3D objects without information.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
dgorsman
in reply to: h_eger
About as close as you are going to get is to export PCF and then import the PCF into AutoPLANT, followed by a fair amount of clean up.  Open Plant is a little more "open" in terms of data exchange but the data still needs translation and the resulting model still needs clean up.
”Boost
