dbconnect manager does not work
Message 1 of 24
Hi everyone
Trying to connect to the SQL database (https://www.youtube.com/watch?v=aCDVQHcHEMI) does not work on my version of plant 3D (2021)
It can not find the SQL so I have to type it manually and then when I connect to the database it takes up to half an hour to load the piping dcf file.
See screenshots
There are no subfolders as shown in the youtube vid
The sql is local on the same laptop as Plant is installed so no firewall issues or other network related stuff. Local is local right?
So why can I make a SQL project without issues but can not use dbconnect?
Please help to fix this thank you
Replies (23)
Message 2 of 24
Message 3 of 24
h_eger
Please check whether the current driver for SQL Server is installed.
Microsoft ODBC Driver 17.7.2 for SQL Server (x64):
https://docs.microsoft.com/en-us/sql/connect/odbc/download-odbc-driver-for-sql-server?view=sql-serve...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 4 of 24
Hi @h_eger
It is installed and repaired it just now. Issues still there 😞
Message 5 of 24
Anyone from Autodesk who knows this?
I cant be the only one facing this issue?
Message 6 of 24
h_eger
It will be the case that you work with this antiquated technology like dbconnect in Plant 3d.
We use the PLANTXDBMANAGER to communicate with external databases.
Open a support case at Autodesk and you will surely get an answer.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 24
I dont know who accepted this as solution but not me.
Anyway I tried this command and still same. Not working
Message 8 of 24
Where do you open support case? They only have forum....
Message 9 of 24
George.Endrulat
We use a combination of SQL database --> Excel --> Plant 3D --> data linked table and plantxdbmanager (for live db connected properties).  Can I ask what you're trying to do with the dbconnect manager?  There might be a different approach.
George
If my post offers a solution, please click "Accept as Solution"
Message 10 of 24
h_eger
Dear @Anonymous ,
I don't know your configuration, but the XDBMANAGER works perfectly for me as shown in the picture.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 11 of 24
@h_eger  @George.Endrulat
I want to see the SQL project database (DCF files of SQLite project) See the video on my first post.
The DCF files contains info of the project but since we use SQL the DCF files are empty.
See the video he shows how to see the data from the DCF files in the SQL server
https://youtu.be/aCDVQHcHEMI?t=1125
Message 12 of 24
Here a vid of what I am doing
Message 13 of 24
h_eger
Dear @Anonymous ,
One of us should check his SQL Server and the access rights: It's not me!
I have recreated your scenario and it works fine for me!
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 14 of 24
Thats awkward....
I can make a project without problems like i showed in the vid..
What needs to be changed to get access to an local SQL instance?
SQL and Plant3D is installed on this pc..... No network nor internet is needed.....
Message 15 of 24
h_eger
Unfortunately, I am not the administrator of your computer.
I am missing the general information about your installation and configuration.
Which version of the SQL Server Managemat Studio do you use?
I am using version v18.6
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 16 of 24
I am using 18.9.1 (latest version) standard installation no settings changed. (SQL server 2019 on WIN10 Home)
Server roles standard as well as access rights.
I can make an new project (SQL based) without issues.
If you want I can make a screencast showing all the settings.
Please note!!
SQL is installed on the same pc as Plant3D
I did not changed anything in the projects (there are 3 test projects as you can see
Message 17 of 24
Anyone who can help me pls? My deadline is coming and it still does not work proper.....
I used the Autodesk PDF about SQL server setup and did everything listed in it.. Even remote connection using TCP.
| Checked the roles and login.... I can make new projects without issues but can not use the DBCONNECT command.....
Message 18 of 24
George.Endrulat
I'm not sure about your problem, but a simple solution to getting your work done might be using management studio to export to excel, cleaning up the excel workbook, then using that data as a data linked table.  This is very one directional, but it does work.
George
Message 19 of 24
@George.Endrulat
My work here is to get the command up and running and not export from ssms... ALl needs to be done straight from within Plant3D and as @h_eger  showed it works for him.. SO what settings needs to be changed that are NOT mentioned in the PDF from Autodesk about SQL???
Again why can I make a new project without issues. Open the project and work in it, But am unable to access the database using DBCONNECT.....
Message 20 of 24
Anyone from Autodesk willing to help with this issue?
