I want to export only LINE NUMBER TAG ,DIA & LENGTH into .xls .How to do this in Data manager
Thankyou
Thankyou
You can create specific export settings in Project Setup.
Just select the fields you want to include in the export. You have to indicate which field(s) provide a unique identifier for each record in the export by ticking the UID column - this is to enable import if you want to make changes. Also, you do not have control of the column order in the exported file.
Andy
