Part of a pipe was lost
Prompt where the piece of a pipe disappears and how to return it into place?
Dear @≡ EqVert ≡,
for the cut piece list, the shortest distance between the objects is always calculated.
For this you have the possibility to assign a length of machining to the pipe sections.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
But for pipes of different diameter length is calculated
Dear @≡ EqVert ≡,
please report this error to Autodesk Support
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hi @≡ EqVert ≡,
The issue where stub-in branch pipes that are equal in size to the header do not have the correct cut length in the isometric CUT PIECE LIST has been logged with our development team.
For now, the only workaround is to manually update the table.
Dan
