Hi All
I have been working on a new custom script for valves & valve bodies. The script works in cad and generates the object when you run the TESTACPSCRIPT command, and did appear in the create new component dialogue box of spec editor. However after fixing an issue in the code and running PLANTREGISTERCUSTOMSCRIPTS, all of my custom scripts have disappeared from the create new component dialogue box of spec editor, including ones I had previously wrote and ones that were purchased. If I run the TESTACPSCRIPT command, the object generates with no issues. Plant 3d, itself, does recognized any components that were created with the other custom scripts. I am just unable to create new parts in spec editor using any custom script parts.
Does anyone know what could cause this issue?
I have tried both Plant 3D 2024 & 2023 and have had the same issue.
Please see attached the python script.
Thank you 🙂
