Custom data binding with report creator
cyklosarin
cyklosarin
It is possible to add into report creator custom data parameters  (class definitions) from the project? I added some parameters regarding P3d Line Group but I cannot use it with report creator. See example bellow:
Best regards
Dominik Ryś
Ensure you've added the parameters to the query and that you have project data checked as data source.
I had the same issue when trying to use drawing data. Switched to project data and the custom values came through.
jabowabo
Are you reporting line group data or piping items data? I would assume the latter. If that's the case, then the properties reported must belong to each item not the owning line group. If you want to be able assign properties to the LG and then report them per item, then you must create acquisition properties for the items to acquire from the line group.
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/CloudHelp/cloudhelp/2018/...
cyklosarin
Thank you guys for help. Both of you are right. In order to extract custom data in report creator project data source must be checked. Single piping data cannot be extracted and grouped by LG parameter. There must be added acquisition property linked to Line Group property to make it works.
Regards
Dominik Ryś
