Copying XML file
Copying XML file
Copying XML file
I created the new project  'Y'  ,when creating the project 'Y', I copied the XML file  from  project ‘ X ‘ .
After creating the Project 'Y' , I added a new block ( new valve ) in the project X .
But  this new block created in Project  'X' is not accessible when working in  project 'Y' .
Pls guide me regarding this.
h_eger
Dear @Anonymous ,
Simply put, not covered in your Plant 3D training?
If you want to transfer configurations from project X to project Y, you should select the Projekt.xml from project X when creating project Y in the dialog or use the project compare from Plant 3D 2022.
Everything else does not work and certainly not just copy the Projekt.xml!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
