Copy Saved Ortho Cube between DWGs or projects
zirudezirude
zirudezirude
Hi Guys,
How can I copy Saved Ortho Cube between DWGs or projects?
Michiel.Valcke
Ortho Cubes that you save are saved as .qry files. By default they can be found in your project folder under the folder Orthos -> Orthocube Library. You can copy these files to other projects.
zirudezirude
Thanks @Michiel.Valcke for quick reply,
I am using BIM360, I copied them through the CollaborateCache but none of them displayed
omiti1
Observer
Observer
*.qry files copied from another project  can not appear in current till they are registered in ortho.dcf , some body shall give procedure how to register them
