Copy drawing to AutoCAD
renan_limaY7LCF
Message 1 of 8
renan_limaY7LCF
Hello friends. I need a help. I need to copy one drawing to Autocad and its don't working.
see below
Thanks a lot
Replies (7)
Message 2 of 8
jflorita
Go to model tab and from there copy the 2d drawing base on the view of your layout.
Let me know if it doesnt work for you.
Message 3 of 8
renan_limaY7LCF
unfortunately it's dont work 😕
Message 4 of 8
jflorita
You have to change the view of the model space depending on the view you selected when you created the ortho view.
Message 5 of 8
norman_duke
I don't think you can copy plant3d objects to a standard autocad drawing. You will to export the source drawing to autocad first then you should be able to copy between standard autocad drawings
Message 6 of 8
jflorita
Message 7 of 8
DVaquand
Hello
What exactly do you want to do?
1. Copy an ortho view to another drawing?
Be aware that an ortho view is a 2D, not 3D, layout of the piping.
Copy/paste works perfectly. You will therefore obtain 2D objects according to the orientation of the ortho view.
In the new drawing it will be necessary either to re-orient the view to correctly see the copied objects, or to do a 3D rotation to place them correctly on the XY plane.
2. Copy the 3D line to another drawing?
In this case you must not be in an ortho drawing but in a 3D drawing.
Copy/paste can work, otherwise you can always run the "ExportToAutocad" command to create a new drawing without Plant 3D intelligence.
== French ==
Que souhaitez-vous faire exactement ?
1 . Copier une vue ortho vers un autre dessin ?
Sachez qu'une vue ortho est un tracé 2D, et non pas 3D, de la tuyauterie.
Un copier/coller fonctionne parfaitement. Vous obtiendrez donc des objets en 2D selon l'orientation de la vue ortho.
Dans le nouveau dessin il faudra, soit re-orienter la vue pour voir correctement les objets copiés, soit faire une rotation 3D pour les placer correctement sur le plan XY.
2 . Copier la ligne 3D vers un autre dessin ?
Dans ce cas il faut être, non pas dans une dessin ortho mais dans un dessin 3D.
Le copiez/coller peut fonctionner, sinon vous pouvez toujours lancer la commande "ExportToAutocad" pour créer un nouveau dessin sans intéligence Plant 3D.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Message 8 of 8
renan_limaY7LCF
