I can convert the part and add ports. Go through the steps in the Custom Part dialog and place it on pipe. The issue comes when I try to copy the part. I get the following error.
This part was created in Inventor and then exported to a 3D DWG. I've attached the DWG file. Does this error happen to anyone else with this file?
I've created other parts with Inventor that have given me no issue at all...
Solved by h_eger. Go to Solution.
Hi @AMS_Aaron,
please test again with the attached drawing.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
OK, that works perfect, thank you!
Any idea what I did wrong, or what was wrong with my block?
Hi @AMS_Aaron,
i have edited the drawing with the PLANTPARTCONVERT command.
Hartmut Eger
Senior Engineer
XING | LinkedIn
This is the same process I followed, but it gave me that error. It's also giving me problems on another block as well..
