Message 1 of 9
Continuing routing a pipeline along direction of existing piping component does not work on Plant3d 2023?
When continuing routing a pipeline after a rotated component using '+', the pipe does not continue at the same angle (as the flange at 4 deg) in Plant3d 2023. However it does continue in Plant3d 2021. I tried to show all the settings used (snap, compass, cutback elbows) in the recording. Cutback elbow is introduced in v2023 somehow, even though the cutback elbow option is not on.
Plant3d 2023
Plant3d 2021
In the attached video I show the same actions in Plant3d 2021 and then in version 2023.
Same project and dwg file was used.
Checked on our specifications and on a build-in cs150 spec.
Best regards,
RS
