Color P&ID as pipe 3D.
How do I set the P&ID colors to match the 3D pipe?
h_eger
Hi @Anonymous,
unfortunately, this feature is not available in Plant 3D.
Alternatively you can adjust the configuration of the colors in 3D.
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Plant3D-UserGuide/files/GUID-9E580DD7-22DC-488A-A081-00F0A74F595C-htm.html
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
