Channel Support Frame Trim/Extend
aforster4PF5F
aforster4PF5F
I'm building a frame using channel but am not sure how to make the middle portion look right. The web of the middle member should only contact the web of the adjoining members. Its the same case with the flanges: the top and bottom flanges of the middle channel should only contact the top and bottom flanges of the adjoining members.
h_eger
Dear @aforster4PF5F ,
Didn't you go over this menu in your training regarding editing Structural Members.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
aforster4PF5F
I didn't have "official" training. I am "self-taught" which is why I am asking a lot of questions. I did attempt to use the commands on the Cutting tab but none of them are working the way that I would expect them to.
t-katsutani
I would have liked such a feature too, but it seems to be difficult in plant3d. you might be able to create what you want using the feature called notch in inventor.
Inventor 2024 Help | To Modify or Apply End Treatments to Frames | Autodesk
