Changing Valve Positions (Specifically Hand Lever)
Might be an easy fix but after alot of searching in P3D and on the forum I can't find anything so I have to think this could also be useful for someone else. How do you change the valve orientation from Normally Open to Normally Closed when modeling. Under Properties>General there is a box that says "Normally" but typing in it does nothing. This should really be a drop down menu that selects Open or Closed.. Or on the actual valve since there are already multiple parameters that can be changed after the valve has been placed. This applies specifically to hand levers in my case.
Thanks in advance!
-Kyle
h_eger
This feature is not yet integrated into Autodesk AutoCAD Plant 3D 2016.
Currently an entry to normally open and normaly cloused is created only in the DB.
Please create a new post on the Plant3D / P&ID Idea Station.
http://forums.autodesk.com/t5/autocad-plant-3d-p-id/idb-p/48/tab/most-recent
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
zirudezirude
By chance, did you figured out that status (open/close) valve in plant 3D model please?
h_eger
No
Hartmut Eger
Senior Engineer
XING | LinkedIn
MichaelCFM
What worked for me in just the 3D model was to copy the valve to a second valve, explode, open block, explode, rotate handle, save block.
(view in My Videos)
EddyWagner
You can transform a block into an operator...
It needs to be a block, then you select this block as an operator — of course, you need to position it in the orientation you want.
But this is purely visual...
If you need something to appear in your isometric, you can use one of the existing Plant properties and use it to indicate whether a valve is open or closed.
These fields could be the Item Code, the TAG, or another one that you are not using...
This setup can easily be configured by a Plant administrator (ADM).
