AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Changing the annotation of valves
20 REPLIES 20
Message 1 of 21
3002 Views, 20 Replies
I am new to Auto Plant for PID. I cannot find how can I change the number of letters of valves. For ex. It seems its set for 2 letters like BV for Butterfly valves, but I need to change it to BFV.
20 REPLIES 20
Message 2 of 21
h_eger
Dear @Anonymous ,
Here you can enter your value "BFV" (1)
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 21
in reply to: h_eger
Thank u so much. And do u know how can I change the size of annotation in the instruments symbols?It is large and touches the symbols, but I want them be inside that. For ex. in a Primary PLC!
Message 4 of 21
in reply to: h_eger
it seems there is some problems. It worked first but when I change the number it shows  BF instead of BFV !!while it is showing BFV at the Edit Annotation !Untitled.jpg
Message 5 of 21
h_eger
Dear @Anonymous ,
this should solve your problem.
Please take care of a training for Plant 3D / PuID it will be much easier afterwards.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 6 of 21
h_eger
Dear @Anonymous ,
after the change in the Plant Configuration please update your project with "PLANTREFRESHACQPROPERTY"
Your changes will be applied to the existing symbols and labels.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 21
Dadspackard
@Anonymous
For the valve type to accept 3 letters do the following
Tom
aka, Dadspackard, Packin31
Message 8 of 21
in reply to: Dadspackard
Great! thanks a lot...
Message 9 of 21
Apparently, it is changing all the valves type tag and all getting 3 characters! which I don't want that...
Message 10 of 21
Dadspackard
@Anonymous ,
If you just want the format for just the butterfly valves you will need to create a new Tagformat
Under the Hand Valve tree select butterfly valve
Go to THE Tag Format select New
Give the tagformat a new name.
Change your tag type length as we did in the above post.
Once you have created your new format under the Butterfly Properties scroll down the TagFormatName and select the new tag format you created
If you don't want the 3 characters for the other valves go back to the Hand Valve Tag(Code-Number) and change it back to 2.
Hope this helps. Others may have a better options.
Tom
Message 11 of 21
Thank you so much. And do you what can I do if want to remove the valve size or change the position of valve tag and size (size # comes down of the valve instead of top)?
Message 12 of 21
I tried to make a new Tag Format. It seems sometimes it works but sometime just brings the ?? instead of the tag name.
Also I cannot change the Field anymore (it is saved by aaa). I don't know why!
Message 13 of 21
Message 14 of 21
Dadspackard
@Anonymous ,
You lost the targets.
Map the fields as follow
Tom
Message 15 of 21
Thanks a lot. Do you have any idea how can exchange the position of valve size and tag number?
Message 16 of 21
Dadspackard
@Anonymous ,
I think this is what you are asking us.
Out of box tag format
You like it to read this way????
If you the like all valves tags to read with the Tag Number on top of valve and size under the valve
Do as follows.
Block Editor will open and you will see the block attributes
(Out of box tag position)
Swap the positions of these two attributes
Close Block editor and Save block
Hope this helps
Tom
Message 17 of 21
Thank you so much...
Message 18 of 21
ruslanvremea
Hello all!
I'm facing some issues with adjusting the valve tag format on a rolling collaboration project following all the steps above. Actually, all I need is to have AAA-NNN instead of the default AA-NNN. But even if I see all the settings to be OK in the project setup, they have no effect on the model.
Message 19 of 21
thomas_roachZD27S
in reply to: h_eger
I was woondering if i can remove that code HA for example on a ball valve. We use our own tags for project scecific.
Message 20 of 21
h_eger
@thomas_roachZD27S ,
delete or replace HA in the Code field with your own values
Hartmut Eger
Senior Engineer
XING | LinkedIn
