I'm running into an issue at work. When I create a new nozzle on my 3D vessel it doesn't give me an option to use a Slip-On Flange. It only shows a welded neck nozzle. How can I get it where I get a slip-on flange option? Please help.
Jeff
This question could be one of two things. One option is if you want to make the nozzel on the tank a slip on flange you will have to edit the NOZZLE Catalog.acat under Cpak Common in your shared content folder and add a slip on flange nozzel as a part. The other way is when you continue pipe routing from this nozzel you want it to place a slip on flange on the pipe side to connect to the tank nozzel. To make this happen you would have to change your part use priorites in your spec to use slip on flanges as your default option (priority 1). This will cause all flange connections to default to slip ons. If this is not desired I would leave weld necks as priorty 1 let it place a weld neck then use the substitution menu to replace it with a slip on.
